Blazer coolant replacement
Old Aug 22, 2009 | 11:04 PM
snaumo's Avatar
snaumo is on a distinguished road
Default Blazer coolant replacement
Can anyone explain to me how to drain, flush, and refill the coolant system in my 1999 Chevrolet Blazer? Including the best way to get at the radiator drain plug? I bought DEX-COOL and a bottle of radiator flush. Please be as specific as possible.
Thank You!
Old Aug 23, 2009 | 02:38 PM
A quick search should give you a number of good ideas. Try terms like "flush", "radiator+flush", "drain", and/or "radiator+drain".
Old Aug 23, 2009 | 11:45 PM
snaumo's Avatar
Can't find anything specific enough
Old Aug 24, 2009 | 12:21 AM
bigdaddykane93's Avatar
bigdaddykane93 is on a distinguished road
STAY AWAY FROM DEX-COOL!!!! IT WILL CORRODE YOUR INSIDES OF YOUR ENGINE!!! drain and flush the system out with the garden hose and run the truck for a little then do it again...then go buy Preston GREEN antifreeze and put 60% distilled water and 40 Green antifreeze..........
Old Aug 24, 2009 | 08:52 AM
Untrue in many respects. If you want to understand where this type of fanatical comment comes from, read through the WHO'S HAD GOOD LUCK WITH DEX-COOL thread in its entirety then if you feel like sticking with that *opinion*, post in that thread. The generally accepted recommended mix is 50/50. For warmer climates, 60/40 distilled water to concentrated coolant may be allowable, but before making statements like that, you may want to take a look at where the OP lives.
So, back to the topic at hand... What, specifically, is it that you are having trouble with? Or would you just like someone to walk you through the whole process before hand...? It is really not too difficult. Just get in there and have at it.
Old Aug 24, 2009 | 03:29 PM
Ugly_Monkey's Avatar
Ugly_Monkey is an unknown quantity at this point
I went to harborfrieght tools and bought this little kit that has a funnel thing and some fittings and a T. you put the T in your heater line then hook a garden hose to it. then you put the funnel in your RAD fillup hole and turn on the hose. it makes a mess though, lol. it sprays all the rad juices all over infront of the truck, lol. but in my opinion if its really dirty in the coolant system youll need to pull your large rad hose and wash it out as it collects alot of the "chunks" in the system. also if the system has alot of "chunks" you may want to pull other hoses too. I say this because if you force those "chunks" through the system u may damage the internals, ie rad or heater.
also it seams to be a little know secret, but the rad drain plug is an alanhead.
Old Aug 24, 2009 | 07:57 PM
My 2000 Bravada rad drain plug was a 1/4" square drive. My 1/4" drive 4" extension fit right in and worked great. Also worth noting that it is only a 1/4 turn valve. Turn more and it'll come out in your hand. It is "fun" to put back in.
The easiest method to drain the coolant is to disconnect the lower radiator hose. It definitely is not the neatest way though.
Old Aug 25, 2009 | 03:26 AM
haha! I think your right I think thats what I actualy meant! oops =P
lionpaw2012
Jun 8, 2015 01:07 PM
AcerDeucerQ
Dec 3, 2012 06:29 AM
dj00140
Apr 26, 2011 06:00 PM
Jonboy
Sep 26, 2010 04:06 PM
Skeeter Cruz
Mar 4, 2010 07:07 PM
