Should I do coolant flush before or after blown intake manifold gasket replacement?
Old May 24, 2015 | 09:54 AM
lionpaw2012's Avatar
lionpaw2012 is on a distinguished road
Default Should I do coolant flush before or after blown intake manifold gasket replacement?
I just discovered that I have a blown intake manifold gasket on my 2004 blazer (overheats, stalls intermitently, coolant in oil,but no oil in coolant) I did a block tester just to be sure it was not a HG. I wanna dive into the replacement but I am not sure if I should do a cooling system flush now or after I replace the IM gasket.
-also, when doing a block test I get a slightly blue green result but not really green or anywhere near yellow, is this a cause for concern or nothing at all?
Thanks in advance for any info, please feel free to elaborate as much as needed.
Old Jun 2, 2015 | 08:15 AM
DesertStorm's Avatar
IMO i think the block test will be fine. If it is overheating and stalling i would not drive it at all. that means it is getting hot enough that it is actually shutting itself down. my advice: park it, replace the gaskets, flush the system.
Old Jun 8, 2015 | 01:07 PM
07nhbpsi's Avatar
07nhbpsi is on a distinguished road
What he said, but drain the oil now........u don't want antifreeze in your oil ....it'll wreck havoc on the bearings in that motor!!!! Your $200 repair will soon turn into a $2000.00 repair!!!!!
limited edition 1
Jan 27, 2023 11:07 AM
awesomeamerican1
Dec 6, 2014 12:01 AM
dunontme
Nov 17, 2009 11:04 PM
ComputerNerdBD
Mar 10, 2009 09:33 AM
portcqb
Apr 29, 2008 09:56 AM
