blazer from hell need help
Old Oct 15, 2012 | 04:06 PM
linedog's Avatar
linedog is on a distinguished road
Default blazer from hell need help
so i have an 01 zr2 from hell, ill start from the beggining
has 138k
random misfire: what i have replaced-
plugs
wires
cap
rotor
coil
spider injection
fuel reg
still misfires like a bas****
the only thing i can think of from his is the distrbutor any suggestions???????
tranny- yesterday i was driving and it quit shifting automatically
could manually shift the gears and it was fine except reverse i would slip in. i get to my destination then 7 hours later i leave and it shifted fine again except i would slip under medium to hard acceleration. today i use the truck again and its slipping again under hard accel went down the highway fine, i get off the ramp to the top and it bogs and stalls, put it in park starts fine throw it in drive stalls again felt as if the torque converter wasnt disengaging did this 4-5 times. i rev up to 2 grand and hold while throwing it in drive and i took off ( zr2 wasnt happy about this) go to drive home after work and drives but slips gears under hard accel. i dont even know where to begin. tranny was rebuilt 4 years ago and has only been driven 8k miles since then (sat 3 years in a climate controlled garage) please throw your $.02 in
Old Oct 15, 2012 | 05:14 PM
warthogdriver's Avatar
as far as tranny did you check to see if its full?
for the random misfire what code are you getting?
any specific cylinder?
Old Oct 15, 2012 | 05:23 PM
linedog's Avatar
tranny fluid is perfect and its a random cylinder misfire
Old Oct 15, 2012 | 07:57 PM
linedog's Avatar
anyone else please and thank you
Old Oct 15, 2012 | 10:52 PM
stoph121's Avatar
stoph121 is on a distinguished road
Has it had major engine work done? Or has the distributor maybe been turned for any reason? Almost sounds like a timing problem to me.
as for the trans, i agree with warthog, checkthe fluid level. Right now the seal on my transfer case is bad and all my trans fluid leaks into there, maybe you have something similar?
Old Oct 15, 2012 | 11:02 PM
xgiovannix12's Avatar
What brand ignition products did you use? These trucks prefer acdelco ignition products..
You can use NGK for plugs also.
IF its a random misfire you should be getting a p3000 code
This might lead you somewhere. P030x - Random/Multiple Cylinder Misfire Detected
Sp33djunky
Sep 3, 2013 11:38 AM
kleps1km
Feb 2, 2012 08:06 PM
slayer35
Dec 30, 2009 10:23 AM
speedfreak81
Oct 13, 2009 06:58 AM
2dr5spdblazer
Jun 16, 2008 10:33 AM
