Blazer keyless entry remote and programming
Old Aug 25, 2014 | 12:08 PM
inscarguy's Avatar
inscarguy is on a distinguished road
Default Blazer keyless entry remote and programming
forgive me if this has been hashed out before. I am new to the forum and I have searched to possibly find the answer but I did not find the exact answer.
I just picked up a '98 Blazer LT for my daughter for a very reasonable price. one of the issues is that it did not come with the keyless remotes. I was able to find two remotes in a junkyard out of a '99 Jimmy and a '00 Blazer. how will I know if these are ok to use on the '98 and how do I program it to work. thanks
Old Aug 28, 2014 | 11:48 AM
inscarguy's Avatar
no one?
Old Aug 28, 2014 | 12:38 PM
richphotos's Avatar
I believe your keyless entry module is behind either the drivers or passenger kick panel, You need to match up the fcc number on the remotes to the module, if they do not match, they will not work.
To program:
1-Close all vehicle doors.
2-Insert the key into the ignition.
3-Hold down the power UNLOCK button on the driver’s door panel-continue to hold down until instructed to release in step 9.
Perform steps 5 through 8 in fairly rapid succession.
4-Turn the ignition switch to the ON position (as far as you can go without starting the engine).
5-Turn the ignition switch to the OFF position.
6-Turn the ignition switch to the ON position.
7-Turn the ignition switch to the OFF position.
8-Release the power unlock button on the door panel. The vehicle will lock and unlock the doors automatically.
9-Hold down the LOCK and UNLOCK buttons on the transmitter simultaneously until the door locks and unlocks. This step may take up to 30 seconds.
Repeat step 10 NOW for each additional transmitter (including any existing transmitters).
10-Turn the ignition switch to the ON position in order to exit the transmitter programming mode.
Old Aug 28, 2014 | 03:34 PM
For what it's worth, I work in a junk yard and I've got 4 key fobs for my 04 now, and I pulled them from various GM's; Caddillac, Buick, Chevy, etc. Not all 4 button remotes work, but there's more out there that will other than just ones from other Blazers. Some have a little picture of a trunk for the rear hatch release but I scrounged up some with the "REAR 2X" on them in good shape and just swapped the rubber button instert over. Fortunately for me, I have the luxury of trying out a bunch of difference ones lol.
Old Aug 30, 2014 | 05:32 AM
inscarguy's Avatar
perfect. thank you.
Old Feb 24, 2019 | 02:56 AM
Bjarne Einar Lihaug's Avatar
Bjarne Einar Lihaug is on a distinguished road
I have a Chevrolet Blazer LT 2001 - European model - keyless remote control with part no GM/UTA 15732810. I have only one key to use and this remote control key is not trustworthy any longer.
Does anyone know about a used or a “new” remote control with the above part no. I would be very grateful to be informed.
Hopefully someone can help or respond to my inquiry.
Best regards
Bjarne Lihaug
catphe10
Feb 1, 2012 09:04 PM
cr8390
27
Jul 9, 2011 02:31 PM
Shonda518
Nov 12, 2010 07:57 PM
lemon blazer
Dec 30, 2007 09:31 AM
dax44
Dec 26, 2006 08:39 PM
