blazer leans to one side
Old Dec 4, 2006 | 03:51 PM
thaasjr's Avatar
thaasjr is an unknown quantity at this point
Default blazer leans to one side
Hi,
I recently had someone point out to me that my 95 blazer leans to one side. After looking it is very obvious. The gap between my tire and fender is 2 inches less on my front drivers side and about 1.5 inches on the rear drivers side. What is causing this? Is it possible that my springs are more shot on that side from me being the only occupant in the vehicle most the time. Don't laugh, its all I could think of. Do I need to replace springs or is there something that I can adjust? Can anyone measure there blazer for me and see if this is typical? I never noticed until it was pointed out.
Thanks
Old Dec 4, 2006 | 04:27 PM
BlazerRJM's Avatar
BlazerRJM is an unknown quantity at this point
Default RE: blazer leans to one side
I also have a 95 blazer, just curious as to what amount of fuel you have in your tank, as the tank is under the drivers seat and rear seat behind driver. I only have 1/4 tank in right now but it does look as though it leans to one side (drivers) a little.
Are you're 100% sure you are parked on a flat surface?
Seems strange that the springs on one side only would go, as they have different charaturistics, if anything they would go in axle pairs?
just my 2 Cents worth.
I will measure my distances once I can get through the snow!
Ryan.
Old Dec 4, 2006 | 07:09 PM
gizwilly's Avatar
gizwilly is an unknown quantity at this point
Measurements on my '95 are within 1/4" of each other. 3/4+ tank of gas, 140K miles.
Old Dec 4, 2006 | 09:42 PM
1996BZR's Avatar
1996BZR is an unknown quantity at this point
are the wheels turned completely straight ahead?
Old Dec 4, 2006 | 09:46 PM
BlazerRJM's Avatar
The left side is about 1/4" lower with a 1/4 tank of gas and 112k miles. It's not exactly parked on a flat spot and I'm sure that is casuing the lean on my vehicle. You should probably check all connections and linkages to make sure nothing has come loose or broke. As far as I know there is no way to change the suspension or spring settings on OE equipment.
Old Dec 4, 2006 | 09:52 PM
a_tack's Avatar
a_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud of
simple question I havent seen anyone ask yet... is it 2wd or 4wd.... because the stock front suspension on a 4x4 is adjustable...
Old Dec 4, 2006 | 09:57 PM
offthehop's Avatar
offthehop is an unknown quantity at this point
Check the body mount under your left foot. If its anything like my 94 theres nothing there and the body is sagging due to lack of support.
Gabe
Old Dec 5, 2006 | 12:25 AM
BlazerRJM's Avatar
"Stock front suspension is aon a 4x4 is adjustable?" That's new to me, how do you adjust it? Very curious as to this new piece of information. Its a MY95.
Old Dec 5, 2006 | 12:29 AM
a_tack's Avatar
you dont have springs on the front of a 4x4 s-series blazer... you have torsion bar suspension... 2wd has coil springs...
the torsion bar bolts.... its not advised to crank them far, but you can go up to 3 inches higher or lower...... just two bolts...... under the truck, not safe to crank them far but it is mildly adjustable with no danger...
mandy0917
Jun 4, 2011 07:15 AM
Wexinlo
Apr 6, 2011 11:35 PM
machine967
Aug 26, 2009 08:14 AM
robedw1
Aug 1, 2008 11:12 PM
tyson0016
Oct 30, 2007 04:41 PM
