blazer not gettin up to temp
Old Nov 6, 2013 | 02:27 PM
Thager's Avatar
Thager is on a distinguished road
Default blazer not gettin up to temp
my 2000 blazer is not getting up to temp , i flushed the dexcrap out and put in the green antifreeze, i back flushed the heater core and everything else seems to be flowing , could it be a bad t-stat, or water pump.
Old Nov 6, 2013 | 02:30 PM
dirt101's Avatar
dirt101 is on a distinguished road
I feel the same way about my truck, I just bought it and the guage only goes up to halfway between 100 and the first hash mark. It has me a little worried.
Old Nov 6, 2013 | 02:32 PM
Thager's Avatar
yeah mine barely moves even after running for 15-20 mins, its been getting cold here -20c so i need it to heat up .
Old Nov 6, 2013 | 02:41 PM
swells87's Avatar
swells87 is on a distinguished road
I would start by checking your thermostat, they are designed to fail in the "open" state, so if it is bad it will let coolant constantly flow. The other thing to try is hook up a code reader and check your temp. that way, possible the gauge is reading right. and do you have heat coming out after 10 minutes or so of running?
Old Nov 6, 2013 | 03:36 PM
dirt101's Avatar
my heat is not all that hot. I think im going to look into replacing the thermostat. do you need to drain the coolant to do it? if not ill replace it tonight
Old Nov 6, 2013 | 03:44 PM
chris015's Avatar
i bet its the stat,replace it either way if its stuck or not,its less then 10 bucks for the stat and gasket.
Old Nov 6, 2013 | 04:15 PM
Thager's Avatar
yeah i bought a new t-stat today ,here there $13
Old Nov 6, 2013 | 05:01 PM
swells87's Avatar
you dont normally need to drain the coolant to replace the tstat, you may lose some so have a little handy, but you shouldnt lose that much.
Old Nov 6, 2013 | 11:11 PM
dirt101's Avatar
Got my thermostat for $6 and tax, replaced it, and the truck gets right up to temperature now. Thanks guys, heat is like 3x as hot now. I lost about a quart of coolant, so plan for that as well. The install was very easy, just have to make room for the T-stat pipe to pull out of the way.
Old Nov 7, 2013 | 12:03 PM
bassson's Avatar
bassson is on a distinguished road
did you get a thermostat that fails open, they are safer if you spend the extra few bucks on those ones, but you should be fine considering that you just replaced coolant and whatnot
