Blazer Running Poorly
Old Feb 10, 2011 | 10:29 PM
fox3r's Avatar
fox3r is on a distinguished road
Default Blazer Running Poorly
So I have been having problems with my Blazer recently running pretty poorly and came to you all for help.
Driving Conditions:
When I get up anywhere from 1500-2500 rpms the car will bog down. It starts chugging and then will go away after a little while or sometimes when I give it some gas it will go away.
Sometimes at stops the idle will be extremely rough and there will be a flickering of the dashboard lights.
At highway speeds (above 55mph) there is a slight jerk while driving and then it will happen again at another time.
Engine Codes:
P0300 - Random Mis
P0340 - Camshaft Pos. Sensor A Circuit (Bank 1 or Single Sensor)
P0108 - Manifold Absolute Press / BARO Sensor High Input
Diagnostic Readout:
Fuel System 1&2 Closed
Calculated Load 17.2%
Engine Coolant: 183 F
STFT Bank 1: 26.5%
STFT Bank 2: 26.5%
LTFT Bank 1: 7.0%
LTFT Bank 2: 5.4%
Manifold Press: 22.1 in hg
RPM: 1686
Speed: 27 mph
Mass Air Flow: 4.75 lb/min
Check:
-Check Fuel Pressure and it was 60 psi at start and never below 55 for 10 min
-New Wires, Plugs, Distributor, Fuel Pump (4000 miles ago)
Just got the P0108 issue today after using Seafoam, but the other have been common codes that I keep getting.
Edit: Just changed catalytic converter and the inside were almost completely dissolved. Most likely to much fuel getting in there. Was wondering what would cause this and if this could be the cause of the misfires.
LesMyer
Jul 15, 2015 10:06 AM
6 gun
Apr 7, 2014 11:09 AM
ksimpson
14
Oct 7, 2013 05:25 AM
English Rose
Jan 8, 2013 01:47 PM
AirJer
Feb 11, 2010 01:44 PM
