blazer running rich
Thanks alot i appreciate it. ill try this out and get back on and let you know if thats the problem.
Well i did the leakdown test, and it was on the verge of going but the pressure is still alright. im going to fix the ventline and see what it does. im a little bit puzzled as to what it is now...really wish i could figure this out.
HI i am having the same problem as well and have not figured out the problem either good luck with yours the people here are very helpful and knowledgeable
Im at a complete loss. i dont want to put money into any parts or anything it doesnt need. i wish i didnt have to guess at it and could just get to the problem.
SlickBlazer, what have they suggested to you?
Last edited by swartlkk; 08-29-2011 at 08:45 PM. Reason: *Combining Consecutive Posts* - Please use the edit function to add additional information in your post if another member has yet to respond.
Don't guess, test. What were the specific results of your fuel pressure test? What was the pressure at prime? What was the pressure 10 minutes after the pump shut off?
Have you pulled the manifold tuning valve off the top of the intake and had a look down inside?
Like swartz says test i tested all things to do with ignition and fuel system .I found a small fuel leak in the fuel line not a dripping leak but i am going to fix it and have to replace sending unit for the fuelk gauge and i believe by fixing the leak in the hose it will fix the problem i am having mine seams to run like it not getting fuel but if i find what mine is i will let you know
ksimpson
14
10-07-2013 05:25 AM
uncledenny
01-08-2010 04:09 PM
oktain
04-29-2009 11:42 AM
