Blazer Runs in Idle and Neutral Fine, Bogs Down in Drive Sometimes Stalls
Old Aug 12, 2014 | 06:49 PM
rexazz2's Avatar
Originally Posted by jb34r5e
EDIT: I put a decent amount of water through my fuel system a while back on accident (fuel can with rain water inside) and am thinking the fuel filter is contaminating my fuel with moisture and could be bogging the vehicle down. I will try this next and see what happens.
throw a can of Sea Foam fuel treatment in the gas tank with the new filter
Old Aug 13, 2014 | 08:16 AM
LannyL81's Avatar
Yep....water in the fuel system is going to cause a problem! Only way to get all the water out that I know of is to drain the tank and blow-out the fuel lines. Adding moisture absorber to the fuel will help a little, draining tank best option.
Old Aug 13, 2014 | 04:08 PM
jb34r5e's Avatar
jb34r5e is on a distinguished road
I replaced the fuel filter today but did not fix the problem. The fuel system seems to be working properly. I think it is an air issue or faulty wiring/plugs. Does anyone know of any commonly faulty hoses or sensors? I will be checking spark plugs, changing cap and rotor and will get back with the results. The RPM drop is preceded by the temp gauge dropping to 0.
Old Aug 14, 2014 | 01:59 PM
jb34r5e's Avatar
I am wondering what people think about this being a possible ECU problem? Since the car drives and runs normally until operating temperature is hit, could it be that the computer is faulty? I just brought my car to Firestone to get tested and they told me I could have a faulty coolant temperature sensor. Would this be worth replacing even though it does not affect the engine or should I try the ECU?
Old Aug 14, 2014 | 10:15 PM
jb34r5e's Avatar
Ok guys, just got back in from working on the Blazer all day. I checked for vacuum leaks, MAF sensor voltages, re-seated all connections (easily reachable) and cleaned them. After an extremely long day, I decided I was going to locate the coolant temperature sensor and check it out. After finally locating it, I found that the input harness on the sensor itself had broken off onto the female wire connector. I was stoked to finally see something wrong with a system that is closely related to the problems and symptoms I've been having. I just removed the old temp sensor and am looking forward to replacing it in the morning. Because the 2 prong connector was semi-exposed ( I could see fresh metal of the prongs, looking down) I believe this is causing my intermittent temp gauge drop offs and coincidental RPM drops due to the mixture/ECM information relay being incorrect or inconsistent due to connection problems!
Here is what the plug looked like when I pulled it off of the temp sensor. Notice that the housing of the sensor is on the plug.
Here, I took the broken housing off of the plug:
Lastly, the broken temp sensor with the housing piece the plug had on it. Name:  arxSuif.jpg
Attached Thumbnails Blazer Runs in Idle and Neutral Fine, Bogs Down in Drive Sometimes Stalls-nrzbalk.jpg   Blazer Runs in Idle and Neutral Fine, Bogs Down in Drive Sometimes Stalls-kuyrzjv.jpg
Old Aug 15, 2014 | 09:52 AM
LannyL81's Avatar
All Right!!...hope this cures the problem.
Old Aug 15, 2014 | 10:00 AM
jb34r5e's Avatar
Thanks man! Will give an update once I put it in after work!
Old Aug 15, 2014 | 08:21 PM
jb34r5e's Avatar
After replacing the coolant temp sensor and making a solid connection, the car has been running smoothly. This case is closed!
Old Aug 16, 2014 | 09:13 PM
LannyL81's Avatar
Another GOOD to read...."Problem solved.".....YES!
Old Aug 17, 2014 | 12:00 AM
jb34r5e's Avatar
Thanks Lanny, feeling good about the fix and hopefully people find this thread useful in the future when running into similar issues.
Juice01
Feb 2, 2013 12:25 PM
benman
Aug 29, 2012 12:45 PM
bam_9_9_9
21
Apr 10, 2011 09:19 PM
jceney87
Jan 24, 2011 07:57 PM
EricTrembath
Jan 19, 2009 04:49 PM
