Blazer stumbles when accelerator pushed hard, No Error Codes
#22
I only had channel locks big enough to try on the vent tube. It wouldn't budge! Then I cut it with a razor knife. Still would budge. I ended up having to cut tube along vent pipe (not across) until I could pry it up then unstick it.
The filler neck tube I jest cut across the tube then once the take was dropped I had to do the same process as the vent tube.
It seemed like it was glued on with a thin cement or maybe they put some type of lube at the factory that acted like glue after 14 years.
#23
Fuel Pump O-Ring
Believe it or not I am still working on this damn thing. When done I'm thinking about taking a trip to GM to slap some engineers.
Now my latest problem:
I have the tank dropped and all cleaned out. Waited a day for it to dry. Now it's time to install new pump.
First I test fitted the pump without the O-ring. Fits perfect, everything lines up.
Next I try with the O-ring. It won't fit!! I coated the seat and O-ring with thin layer of lube. Still no luck. I'm afraid something is going to break if I push any harder. It needs to insert far enough to get a horseshoe clip to engage.
What's the secret to getting this pump to seat properly?
#25
Thanks for the reply. I finally gained the intelligence to compare the new O-ring to the old one, The new one is slightly thicker and not as pliable. It is also black when the oem is blue.
The pump was oem bulk pack, so they probably lost the original and put one that looks like it will work but is slightly off.
When I did a test fit with the old ring the pump went in perfect.
So now I have to wait until Monday for an O-ring that I ordered for $6.00.
#26
New Fuel Pump Installed
It took a few weeks to get it done but now the new fuel pump is installed.
I have been test driving for a little over a week.
The problem is fixed!!
Thanks to all who helped.
Next . . . . the water pump.
Mark
Mark
#27
I noticed this problem when I got my Blazer back from the shop. It would only really do it in first gear, but it did it enough where I would notice it. I figured maybe the fuel pump is going, but didn't do anything about it. Sure enough 2 months later, I'm stuck in a parking lot, engine is cranking, but just won't start. Hit 500 rpms first try and stalled, then never got any response again. Was quite fun, and I mean depressing.
glitch006
11-16-2014 09:17 PM
ryanpraski
11-17-2010 08:13 AM
jason71832
02-23-2010 07:20 AM
LS Blazer
01-07-2008 02:20 PM
