blazer wont idle down until stopped
I just bought a 02 blazer with a 4.3, my problem it won't idle all the way down until I've been stopped for a second or two, the idle will drop about 400 rpm to about 750 rpm. Also I can let my foot off the brake and after it starts to roll the idle will jump up about 400 rpm without touching the gas pedal .
https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/found-my-problem-42968/ check this out. apperntly if your alternater voltage isnt spot on your ecm will get confused. i am having the same issue as you and i think this is the problem. i will put multi meter on mine hopefully tomorrow and post back with results
My 1996 MT 2dr Blazer has had this problem too ( engine would rev over 2,000 RPM's). It seemed to get worse when it got cold, and I finally bought a GM Throttle Position Sensor ( 64 dollars ), replaced it in 5 minutes. Since the IAC is the TPS close neighbor, I took a good look at it too. I think the carbon built up in the IAC passage to the throttle body, and was hindering the IAC plunger to fully seat. So I figured I'd take out the IAC ( 2 torx screws and a wire to disconnect ) and clean the plunger on the end with aerosol throttle body and intake cleaner. Then I sprayed the passage connecting the IAC to the Throttle Body, where the IAC plunger seats. To get it good and clean put on a cheap cloth glove, and spray TB cleaner on the pinky finger tip and give the aluminum seat a cleaning ( like you'd use a Qtip to clean your ear ). The cleaning and reassembly of the IAC took about 15 minutes. Between these two things, my truck is running great. Hope this helps.
Jim
Jim
syriusly
Feb 23, 2013 07:04 AM
DarlingReject
Feb 3, 2013 06:58 PM
97BLAZE4X4
Feb 7, 2010 07:33 PM
