Bogging down when at idle/ Rough Idle solution
Old Feb 7, 2010 | 04:18 PM
97BLAZE4X4's Avatar
97BLAZE4X4 is on a distinguished road
Default Bogging down when at idle/ Rough Idle solution
New here,
Just wanted to possibly help someone concerning bogging down when at idle, or a very rough idle. I first noticed this problem in December. I started my blazer up (97 4x4) and it would idle fine for one second then cut out and over/under rev itself. To the point where it would shake the whole car. Like it was going to stall almost. The problem was the PCV line, I know on mine It had pretty severe rotting and you could hear it sucking air. I simply replaced with fuel hose conected both ends and it ran like a gem. Have not had a problem sence. To where this is located is behind the TB, on the drivers side of the engine, you can find the line simply by looking for the PCV, which is set in the engine. The old line runs partly under the TB, the faulty piece is a L shaped plastic piece with the rubber boots and fitting being the issue. Hope this helps!
Chris
Old Feb 7, 2010 | 07:33 PM
Spectreblazer's Avatar
Banned
Spectreblazer is on a distinguished road
welcome from MI, chris
cubcadet
Dec 7, 2009 02:58 PM
96jimmy03us
Nov 18, 2009 08:33 PM
schimmi021
14
May 18, 2009 12:15 AM
ScottECU
Mar 13, 2009 12:26 PM
juanhenry
Dec 30, 2007 01:45 PM
