Blazer Wont Start When it Rain Heavy
Old May 2, 2016 | 08:13 AM
dbpowell's Avatar
dbpowell is on a distinguished road
Default Blazer Wont Start When it Rain Heavy
98 Blazer that I purchased for my son. Every time there is a heavy rain storm and the Blazer hasn't been ran in a few days it wont crank(NO FIRE). After the rain storm open the hood and in about 30 to 45 minutes it will crank(spit and sputter for a few seconds ) and run fine.
I had heard that there was an issue with water dripping down on the distributor. I have sprayed drier and sealant on cap,wires,coil modules and all wires leading to and from the before mentioned.Had rain here Saturday and Sunday and yesterday morning my son went to leave and it wouldn't crank.Run through my same fix again(open hood etc) and it cranks.
What could I be missing and help or advice would be greatly appreciated. Thanks in advance
Darrell
Old May 2, 2016 | 08:27 AM
Raybz's Avatar
Raybz is on a distinguished road
Just had this with my wife's Blazer....drove me nutz
Have a look at the coil
Spray some water on it when the truck is running
I'll bet up to and including ONE dollar it dies as soon as the water hits it
Old May 2, 2016 | 08:36 AM
dbpowell's Avatar
Thanks Raybz.....will try it tonight when I get home
Old May 2, 2016 | 10:58 AM
dbpowell's Avatar
Forgot that I brought it to work with me today. Drowned the coil while it was running and no change. Also forgot to mention earlier that new cap and rotor have been installed when I got the Blazer
Old May 2, 2016 | 11:14 AM
Raybz's Avatar
What brand cap and rotor? These things are pretty particular and wand AC Delco.
Did you put dielectric silicon on the rotor and contact points?
Are you sure it's spark related? Could be a bad ground or exposed hot wire on the fuel pump shorting when wet. Could also be the connector at the fuel pump. Have you cleaned the MAF sensor?
I'd pick a direction and follow it to the end, like no/weak spark Then start looking at fuel related issues.
Seems your coil is Ok....next is the Disty, then wires, then plugs ect. A spray bottle and water can be invaluable. Hit things one at a time till something changes
Old May 2, 2016 | 02:01 PM
dbpowell's Avatar
-Cap and rotor brand- Don't know but do know that it was new one put on when motor was put in.
- Fuel pressure is good with key on at start and after cranking on it a few times fuel smell everywhere
- I have a sneaking suspension that it is in the Distributor area...Going to check those tonight when I get home from work. Its raining right now so can't check it. Not worried about it starting when i leave to go home because it typically only happens after long rains and days of not driving. Thanks
Old May 2, 2016 | 02:35 PM
newguy's Avatar
shouldnt be any fuel smell, something is wrong there
Old May 2, 2016 | 06:03 PM
donald_archer's Avatar
donald_archer is on a distinguished road
I know this has already been proposed but same thing happened to my '98. Turned
Out to be the coil. Replaced it and had no further problems. Good luck
koreiryuu
Feb 23, 2015 05:26 PM
shotnva777
25
Sep 27, 2011 07:04 PM
mike frederick
Jul 19, 2011 10:48 PM
kati95
Mar 9, 2009 10:06 PM
Argo123
Sep 17, 2008 05:32 PM
