Blazer Xtreme Shocks Replacements HELP????
i have an 03 xtreme blazer with 154k and has the original shocks on it, so id like to replace them but im having a hard time finding good ones that make them for the front and rear. I wanted to put KYB but they tell me they dont make rear shocks for the blazer xtreme. They only ones ive found that i think are good are Monroe Relex shocks. If anyone has any suggestions and part numbers that would be much helpful.
It depends what kind of ride you want. Monroe Reflex Monotube is a step above the Sensa-trac. It has a larger cylinder, and the ride is much more firm. Sensa-trac is more of a "car" shock and gives a "mushy" ride whereas the Monotube is noticeably stiffer and more "heavy duty".
If you CAN find a KYB shock replacement, I recommend the Gas-A-Just. It's a monotube shock with a nice and firm, but not too rough of a ride. I've been pleased with the results. The Shocks were about 40-45 bucks a piece from Amazon.
I had sensa-tracs on for about two weeks and removed them as the ride was worse then the old shocks they replaced. The ride was rough and squishy.
BTW, I drive a 98 LT 4dr.
95LS
19
Oct 21, 2012 03:04 AM
tim03parts
Jan 7, 2008 09:08 AM
