Blazer Xtreme Shocks Replacements HELP????
Old Apr 18, 2012 | 10:40 AM
cory30189's Avatar
cory30189 is on a distinguished road
Default Blazer Xtreme Shocks Replacements HELP????
i have an 03 xtreme blazer with 154k and has the original shocks on it, so id like to replace them but im having a hard time finding good ones that make them for the front and rear. I wanted to put KYB but they tell me they dont make rear shocks for the blazer xtreme. They only ones ive found that i think are good are Monroe Relex shocks. If anyone has any suggestions and part numbers that would be much helpful.
Old Apr 18, 2012 | 12:37 PM
50lb_cat's Avatar
It depends on how much you want to pay. I have had good luck with monroe sensatracs. I put on all 4. Not sure if they will fit the xtreme. Have yoh looked into rancho or bilstein?
Old Apr 18, 2012 | 01:11 PM
cory30189's Avatar
i figured on paying 30 to 50 a shock for good ones. I dont want bilstein and i couldnt find rear shock from rancho only the front.
Old Apr 18, 2012 | 01:49 PM
It depends what kind of ride you want. Monroe Reflex Monotube is a step above the Sensa-trac. It has a larger cylinder, and the ride is much more firm. Sensa-trac is more of a "car" shock and gives a "mushy" ride whereas the Monotube is noticeably stiffer and more "heavy duty".
Old Apr 18, 2012 | 02:03 PM
cory30189's Avatar
i want more of a firm ride, mine is very mushy and has lot of roll to it.
Old Apr 18, 2012 | 02:33 PM
The Monotubes will stiffen it up and keep body roll to a bare minimum. Check your sway bar end links, front and rear, make sure they're good. A broken end link will cause excessive body roll.
Old Apr 18, 2012 | 05:06 PM
joey's Avatar
joey is an unknown quantity at this point
If you CAN find a KYB shock replacement, I recommend the Gas-A-Just. It's a monotube shock with a nice and firm, but not too rough of a ride. I've been pleased with the results. The Shocks were about 40-45 bucks a piece from Amazon.
I had sensa-tracs on for about two weeks and removed them as the ride was worse then the old shocks they replaced. The ride was rough and squishy.
BTW, I drive a 98 LT 4dr.
camarodude13
Feb 8, 2013 12:31 PM
95LS
19
Oct 21, 2012 03:04 AM
tim03parts
Jan 7, 2008 09:08 AM
01BlazerLT
Jun 25, 2007 05:10 PM
