Bleeder nipple on bottom of caliper?
Old Oct 14, 2011 | 05:58 PM
pbd3mon's Avatar
pbd3mon is an unknown quantity at this point
Default Bleeder nipple on bottom of caliper?
Hi, I have a 2004 Blazer RWD and I'm in the process of fixing my rear brakes (rotors, pads and calipers) and I noticed something really odd; the bleeder nipples are on bottom of the calipers. I find this really odd because according to my logic I will not be able to bleed out the air after replacing the calipers. I have not changed the brakes since I bought this car. Any input on how to install the new calipers would be greatly appreciated.
Old Oct 14, 2011 | 06:19 PM
maddie's dad's Avatar
maddie's dad is on a distinguished road
That really is odd. Could it be that the calipers were swapped from opposite sides of the trucK? I did this once on an old datsun station wagon's front calipers.
If there is only one bleeder, then the calipers are on the wrong sides of the truck.
Old Oct 14, 2011 | 07:57 PM
pbd3mon's Avatar
Yes there is only one bleeder per caliper on both the old ones and the new ones. So you're saying that I should definitely install the new ones making sure the bleeders are oriented on top of the caliper?
Old Oct 14, 2011 | 07:59 PM
That's the only way they will be effective.
Old Oct 14, 2011 | 08:05 PM
pbd3mon's Avatar
Ok thank you, I will try it tomorrow and I will keep you posted.
Old Oct 14, 2011 | 08:12 PM
The part numbers on the new calipers should tell you what side they are supposed to go on. What are the part numbers & brand of the replacement calipers?
Old Oct 14, 2011 | 08:16 PM
69chevelle's Avatar
69chevelle is on a distinguished road
as previously stated, if the bleeder is on the bottom it is mounted on the wrong side. You can install the left caliper on the right side but the bleeder will be on the bottom as apposed to the top.
If both bleeders are on the bottom then swap calipers from side to side, if only one bleeder is on the bottom you have two of the same calipers(ex, 2 left side calipers, making the caliper on the right the one that is upside down)
As stated, the bleeder screw has to be on top to be effective because you are letting out the air and air goes to the highest point.
Old Oct 23, 2011 | 01:45 PM
pbd3mon's Avatar
Sorry for the late reply had some catching up to do after go the car fixed. You guys were absolutely right it had to be facing up. The repair went smooth. Once again thank you for all the replies.
metalmeltr
Jan 25, 2014 04:44 AM
bugsbunny16374
Jul 27, 2010 11:10 PM
jimminiquick
Aug 3, 2009 12:35 PM
chevyman30571
Feb 18, 2008 10:35 PM
