Blend door actuator
Old Aug 22, 2013 | 05:34 PM
BlazerRazor's Avatar
BlazerRazor is on a distinguished road
What's the part number? I'm trying to find it on this diagram and I think I'm going blind...
Old Aug 22, 2013 | 07:38 PM
This is the blend door actuator for the C60, manual HVAC system: Item Details
The actuator can only be installed one way, and the door will automatically be in the correct position. DO NOT operate the actuator without installing it. If you do, the actuator will overtravel and destroy itself. On the manual HVAC system, (C60) the calibration procedure is not necessary, it's plug & play.
Old Oct 5, 2013 | 08:43 PM
Chris Jessee's Avatar
Chris Jessee is on a distinguished road
I have a 96 Jimmy with manual climate control. I now only have hot air with temp selector in all positions. Everything else works as it should. Could this be a blend actuator problem? If so, how do I access it on a 96 Jimmy?
Old Dec 13, 2013 | 10:05 AM
sparkysblazer's Avatar
sparkysblazer is on a distinguished road
I'm having heat issues also, after battery replacement. Is that TSB info available? Thanks!
Old Dec 31, 2014 | 12:52 AM
notblonde's Avatar
notblonde is on a distinguished road
rich4149, did you ever find the procedure for calibrating the unit. I tried finding the TSB 150-9645 you mentioned but can't find it either. Any help would be appreciated!
Old Sep 14, 2017 | 12:23 PM
cudaguy71's Avatar
cudaguy71 is on a distinguished road
Originally Posted by rich4159
if after you figure out which blend door actuator you need to replace manual or auto, you may end up with a very common problem were the blend door is cycling and unable to find it's limits. This problem has driven me crazy for six months since i changed the battery out. All the threads here and on most other sites give the basic calibration procedure. this says to remove the dro bat fuse for 20 seconds, with the power off, then put it back and turn the key to the on position for 40 secs. all good except it is missing a very key step.
I have finnally nailed the problem down thru an honest Chevy mechanic. "this is a known problem throughout many of the chevy product lines. in order to fix it the five volt signal needs to be jumped to one of the pins on the connector to the unit can first find it center positon. The aforementioned cal procedure can only find the limits but without the center position being first calibrated the DRO bat fuse removal procedure cannot work". This is exactly what i see happening. Chevy does have procedure for calibrating the unit about $100.00. but not to fret. there is a tsb 150-9645 that explains which pins to jump. I will post it as soon as i can. i did the procedure last night and it work!
Of course this is a real design issue that chevy will not take responsibility for and therefore they expect the owner to pay a 100.00 fee. Change a battery and then pay $100.00 to have heat and air conditioning again.
go figure.
Did you ever post the tsb 150-9645? Thank you...
Old Oct 16, 2017 | 11:13 PM
Looks like I'm not the only one with an HVAC air temp issue. Mine is only delivering hot air through my Automatic HVAC system.
Any luck with the TSB?
Christine
Old Oct 17, 2017 | 07:37 AM
LannyL81's Avatar
cudaguy71 and christine_208: since this thread is about three years old, doubt that the TSB was ever posted here, might try doing a Google search for it.
Are you both having hot air out the vents with AC on? Assuming the AC system is functional, easy thing to do is to watch the blend door actuator movement with the temp setting at full hot, then full cold...or the other way....just to see if it is moving then we can go from there.
Old Oct 17, 2017 | 08:02 AM
cudaguy71's Avatar
Tried Google but found nothing on TSB... Yes blowing Hot air auto HVAC, the blend door does move though not fully from one end to the other... I moved it manual to the cold side and have cold air but it won't move back for heat... This problem happened when I had a dead battery, I have tried the re-learn several times... cudaguy71
Old Oct 17, 2017 | 11:54 AM
Default theorizing...
I just looked at mine again, I could hear the blend door actuator motor running with the key in the RUN position but motor off. What I did not hear is anything that sounded like a door moving back and forth.
I recently had to put a new battery in my Blazer but I cannot be sure if the actuator went bad at the same time. However, looking at online videos I can see how it could only take one bad (i.e. hard to move) situation for the key gear to crack. Perhaps the motion associated with the re-initializing of the actuator after losing power puts extra strain on an already weakened gear, hence the correlation between disconnecting the battery and these actuators going bad.
Christine
