Blend door actuator
Blend door actuator
So, I did my blend door actuator yesterday (I have the auto AC system). The problem I was having is that I had heat when it was all the way up, but as soon as I turned it one notch down I only had cold. So now that I have the new motor in I only have heat. No matter where I set it. Didi I install it wrong? Or do I have a bad actuator?
Nope, and those systems won't do what your ATC system can do when it's working properly
You will need a bi-directional, (high end) scan tool that can access the BCM. You'll need it to retrieve trouble codes, help diagnose the system, and perform functional tests. Or you can keep guessing which part is bad
BCM DTC's will NOT turn on the check engine light.
I just re-read the how to thread how to do the blend door actuator and noticed something. The vacuum actuator that is in front of the blend door actuator, what does that operate? I noticed that mine is no longer connected to anything. The plastic arm that it connects to looks like it is broken off. I noticed that when I replaced the blend door but then forgot about it after the entire ordeal.
What color is the vacuum line on the actuator?
EDIT: Scan XL Pro is a step above entry level scanners, but even their
"Enhanced GM" upgrade will not access the BCM.
Unless it has been replaced, black is typically the vacuum source. It should have vacuum in every position of the mode switch with the engine at idle. The manual HVAC system, and the automatic climate control, both use electronics to control temperature, not vacuum. Really think you need a capable scan tool for this one
