Blend door actuator
Old Feb 22, 2016 | 10:14 AM
  #21
Did you ever repair the broken piece in post #7?
Old Feb 23, 2016 | 07:03 AM
  #22
Tajohns34's Avatar
I did not. I need to figure out what it is and order a new one. I will see if I can get a picture after work and post it. My fear is that I have to pull the dash to replace it.
Old Feb 23, 2016 | 10:41 AM
  #23
Heater case will need to be removed and disassembled, right after you remove the dash
Old Feb 24, 2016 | 10:59 AM
  #24
Tajohns34's Avatar
It was really hard to get a camera in there to take a picture. But there is a vacuum operated arm that is white plastic that the end is broken off of. It is just to the left of the blend door motor.
Old Feb 24, 2016 | 06:10 PM
  #25
Slave door actuator linkage. You'll end up at the dealer or a boneyard, (GM only, not available aftermarket).
Old Feb 25, 2016 | 07:07 AM
  #26
Tajohns34's Avatar
Ok, that helps a lot. I will see if I can snag one the next time I am at the yard. I will plan on replacing it this summer. Just out of curiosity what does that part do?
Thanks!
Kidkaos70
Apr 20, 2011 11:35 PM
ravenhurst
Feb 16, 2010 05:53 PM
stickemdano
Nov 14, 2009 11:13 AM
markrd
May 8, 2009 01:39 PM
