Blonde with a misbehaving blazer
So.... 2001, 2 door, 4wd blazer. Parked on incline at bank and when got back in it wouldn't start. acted like wanted to but just didn't. the boyfriend came to my rescue and after some trouble shooting we put some gas in it to see what happens.. oh it starts right up. It wasn't out of gas though. the light wasn't on and I had at worst 1/8 tank left. been fine since. Today parked on incline and same thing. won't start but acts like it want to....at this point we think something is clogging something . we push it to flat surface. same thing... won't start. so jump on bumper to slosh things around. won't start. mope around apartment for 10 mins and give one last try... it starts!!!! YaY!!! this time I had over 1/2 tank full.
What in the world is going on! I want to get a clue before I resort to taking it to mechanic on Monday. is this just a simple fuel filter that need replaced? or a (shudder) fuel pump? or something different. I'd like to figure out if something the boy toy and I can do. He is somewhat mechanically inclined. me not at all but I have the heart and no money....
Okay...1/8 tank of gas, parked on incline...fuel pump sucked air and probably any "gunk" that it could. Hopefully the fuel filter caught it all, but not it may be so clogged-up that not enough fuel is getting to the engine....or the fuel pump pick-up "sock" is clogged-up.
Fuel filter change is a bit of a pain; have to be careful with the fuel line fittings...use a flare nut wrench or you'll be in real trouble. Spray lube onto the threads and let soak for a bit before trying to get them loose. Relieve fuel pressure before putting wrench to fuel line fittings by pressing scharder valve on backside of intake where fuel lines are.
Still may need to drop fuel tank and clean fuel pump "sock"; actually just replace it....they are cheap.
Couple of things to know before dropping fuel tank. Let us know what you find out and if fuel tank drop is required, will fill you in on those hints.
Good luck.
Good luck.
Melrock83
09-26-2012 02:27 PM
