Brake bleeding question
Old Mar 13, 2008 | 10:02 AM
portcqb's Avatar
portcqb is an unknown quantity at this point
Default Brake bleeding question
I'm going to do a rear brake job on my '97 Bravada. I was wondering if change the rear calipers do I need to bleed all wheels or just the Caliper(s) I change?
Old Mar 13, 2008 | 11:30 AM
Default RE: Brake bleeding question
At the very least, the rear. I would consider bleeding the entire system to remove all of the old brake fluid, flushing the system until you get clear fluid out at each wheel. Start at the passenger rear, then driver rear, passenger front, and driver front last (order from longest distance to the master cylinder to the shortest). Make sure to keep the master cylinder full!
As brake fluid ages, it absorbs moisture which can hinder its ability to withstand heat. If you are already going to be doing 2 wheels, it isn't that much more to do all 4!
Old Mar 13, 2008 | 04:25 PM
portcqb's Avatar
Thanks for the info.
whoareyou4
Sep 4, 2011 04:22 AM
jess1327
Mar 12, 2008 11:37 AM
Hanr3
Nov 23, 2007 08:26 PM
97Blazer15
Apr 26, 2007 07:21 PM
Dj7763
Mar 10, 2007 10:41 PM
