Brake Booster Vacuum Line Leak?
Old Nov 17, 2015 | 08:11 PM
haliphics's Avatar
haliphics is on a distinguished road
Default Brake Booster Vacuum Line Leak?
So the other day, I guess I had a lean missfire that shot off the brake booster line from the engine. Once I figured out it was that, it looked like all I has to do was just put in back in by matching the tabs, instering, then twisting. But ever since then it sounds like a air hiss from that hole, my car is ultra sluggish from a stop to acceleration, and when I turn off the engine when the hood it open about two seconds after the engine is off the hissing goes away too. Is there a type of sealant or maybe o ring that should be in the port on the engine that holds the line on or am I missing something?
Old Nov 17, 2015 | 08:27 PM
What year?
Old Nov 17, 2015 | 08:28 PM
haliphics's Avatar
Originally Posted by Captain Hook
What year?
1996 GMC Jimmy, sorry I forgot to include that.
Old Nov 17, 2015 | 08:34 PM
Does this look like the part that you're referring to? Dorman - Help PCV Valve 47026: Advance Auto Parts
Old Nov 17, 2015 | 08:36 PM
haliphics's Avatar
Kinda except it's a single L shape in into the engine with no other ports to attach hoses. I can take a picture of that'll help.
Old Nov 17, 2015 | 08:37 PM
Pix are always good
Old Nov 17, 2015 | 08:47 PM
haliphics's Avatar
Pix are always good
Here they are
http://imgur.com/a/QwDEA
Old Nov 17, 2015 | 09:27 PM
Needs to be an O ring on the fitting, and the "ears" are distorted, that's why it popped out. Boneyard or GM dealer.
Old Nov 17, 2015 | 09:32 PM
haliphics's Avatar
Thank you so much. Is there a specific size o-ring?
Old Nov 18, 2015 | 02:54 PM
I suppose there is, and the dealer would most likely know. Sorry, can't help you on that one.
