brake lights
Old Oct 12, 2008 | 06:22 PM
woodworkewr4421's Avatar
woodworkewr4421 is an unknown quantity at this point
Default brake lights
hello i have a 1997 blazer with no brake lights. none on the sides or on the brake strip.tried to replace the flashers no help. replaced the brake switch on the brake pedal, no help.i also have no four ways. turn signals work.when i put the turn signals on and push the four way switch the turn signals stop flashing on th edash.the bulbs looked ok. check every fuse ok. any help would be nice. i have a 96 blazer for parts.
Old Oct 12, 2008 | 08:22 PM
Peru Motors's Avatar
Peru Motors is an unknown quantity at this point
Default RE: brake lights
make sure that the multi function switch is the same for your 96 and that all it's functions work(that don't on your 97) and if it's worth it to you switch the switch! You can take it off the 96(if it crosses) and plug it in under the dash b-4 routing and mounting it to see if that is your issue. Good luck JP[sm=ts.gif]
Old Oct 12, 2008 | 10:06 PM
Just to cover the basics first, you checked that your STOP/HAZ fuse (fuse #1 - 20A) is in good working condition, testing it for continuity, correct? I am not stating this to be funny or to insult you. I know I have looked at all of the fuses in the fuse box before when troubleshooting electrical problems only to have a fuse look good, but test open. Sucks when you spend a butt load of time ripping a ton of stuff apart only to find that you missed something so simple in the beginning.
This could be caused by a faulty Hazard switch, but that would not explain why the third brake light is not working... The only common item is the STOP/HAZ fuse.
*EDIT* - Here are some items that may be useful to you:
Old Oct 16, 2008 | 08:20 PM
sorry the third light works. i applied the brakes and moved the hazard button and the lights worked. shoved paper to hold . sounds like the switch is bad. tried to take my other one out but cut wires. thanks for the replys
Old Oct 16, 2008 | 09:35 PM
You can replace just the hazard switch, but check to see if your vehicle is covered by a recall first.
edavison
Dec 20, 2010 09:55 PM
step66
Oct 14, 2010 04:52 PM
SCBlazer96
Apr 16, 2010 08:39 PM
dashyman
Jan 12, 2007 11:28 AM
rryker
Apr 25, 2006 04:14 PM
