brake lights hand holding
Old Oct 8, 2010 | 07:33 PM
brokencookie's Avatar
brokencookie is on a distinguished road
Thumbs up brake lights hand holding
After looking through the forum and archives I think I have figured out the problem. But I could use a little hand-holding to complete the problem solving. Here Goes
1996 Blazer LS ( 7 pin trailer hookup)
No brake lights ( top or bottom) No hazard lights. All new bulbs, new brake switch installed. The stop fuse is good. The Hazard / stop fuse keeps blowing.
When I install a new fuse in the Hazard /Stop spot the brake lights flicker and then the fuse blows. Same for the Hazards, new fuse, 1 pulse and blown fuse.
BTW, turn signals, tail lights etc all work fine.
This leads me to believe that the famous multifunction switch is bad. ( replaced once in 2006). or that the trailer wiring has gone south.
Opinions welcome
Thanks in advance
Bruce
Old Oct 8, 2010 | 07:38 PM
blazerpower's Avatar
blazerpower is on a distinguished road
i would say trailer wiring. i had 2 plugs in mine for some reason and one of them would short out when you hooked it up.
Old Oct 8, 2010 | 09:40 PM
After you pull down the trailer wiring and have a look there, pop out the hazard switch. The hazard switch is VERY common.
Old Oct 9, 2010 | 09:42 PM
Default Yay !!!
Thanks for the help and confirmation. I found the problem in the tailer wiring and now everything is working
BlazinHo
May 11, 2014 06:09 PM
jbordi
Mar 25, 2011 06:20 AM
Tony H
Apr 6, 2010 12:18 PM
frank29
Mar 2, 2008 03:51 AM
gmyoyo
Nov 7, 2005 02:42 AM
