brake noice expecially when turning right
Old May 2, 2017 | 06:13 AM
kmartin's Avatar
kmartin is an unknown quantity at this point
Default brake noice expecially when turning right
I have 2003 Chevy Blazer and over 130,000 miles on it. For a while, it sounded like occasionally that my low brake indicator were making a noice. From the rear. Not all the time. Replaced brake pads and rotors like over 15,000 miles ago. It really becomes strong when I turn to the right. ANy ideas what that is?
Old May 2, 2017 | 01:19 PM
chevy77's Avatar
chevy77 is on a distinguished road
might want to check the dust shield behind the rotor sometimes they get bent and rub you just have to bend it back out of the way
Old May 2, 2017 | 04:10 PM
kmartin's Avatar
How do you know when to consider the caliber. I thinking my passenger rear wheel is where the problem is. The one pad got worn down to nothing before even the front pads. I sometime smell a burnt smell at that wheel after driving.
Old May 2, 2017 | 05:09 PM
Brian Hinzpeter's Avatar
Brian Hinzpeter is on a distinguished road
Is one side worn down to nothing while the other side is ok?
Old May 3, 2017 | 05:42 AM
newguy's Avatar
final answer, wheel bearing
Old May 3, 2017 | 09:53 AM
chevy77's Avatar
if the pads are wearing down fast and you can smell burnt brakes you probably have a stuck piston in the caliper next time you have the burnt smell jack it up off the ground and try to turn the wheel by hand if there is any resistance the caliper is stuck and you will need a new one
Old May 3, 2017 | 09:09 PM
kmartin's Avatar
I took a look underneath and I did notice the dust cover is rusted bad. Has holes and sticking out some place.
Old Jul 1, 2017 | 02:42 PM
kmartin's Avatar
Looking into replacing the dust covers, I saw the parts are not expensive, but getting them replaced is quite the process. Is it ok to let go till the next brake work? Could I be letting worse happen if I do?
68Datsun510
Jul 19, 2012 08:35 AM
vankuen
Mar 24, 2008 09:24 AM
wolves0309
Dec 17, 2007 04:05 AM
cmblackburn
Apr 11, 2007 10:30 PM
chvycmaroz28
Sep 22, 2006 04:10 AM
