Brake problems
Old Apr 4, 2015 | 08:35 PM
britspares's Avatar
britspares is on a distinguished road
Default Brake problems
Have been having issues with front brakes dragging on my 99 s10 blazer, well replaced both lines, calipers movement fine after doing the work now all 4 wheels drag could it be the master cylinder HELP.
Old Apr 5, 2015 | 07:22 AM
britspares's Avatar
Default BRAKE Problems
After replacing 2 front brake lines I still have a dragging problem, but now its all 4 wheels , could this be the master cylinder ?
Old Apr 5, 2015 | 11:24 AM
Open up a bleeder and see if it changes how easily the wheel rotates.
Old Apr 5, 2015 | 01:42 PM
britspares's Avatar
Default brakes
Yes I have tried this, but it does not release.
Old Apr 5, 2015 | 01:45 PM
Then the problem is either a stuck caliper piston, or binding hardware, (guide pins etc).
Old Apr 5, 2015 | 01:50 PM
britspares's Avatar
after fixing the front lines, cleaned pins etc.., now the rear and front are dragging
Old Apr 5, 2015 | 01:52 PM
britspares's Avatar
could it be the master cylinder ?
Old Apr 5, 2015 | 02:19 PM
Opening the bleeder takes the master cylinder and lines out of the equation. A stuck piston or binding hardware are the only possibilities.
Old Apr 6, 2015 | 06:22 AM
britspares's Avatar
Default dragging front and rear brakes
although the rear was not dragging as much as the front , I called a master mechanic I know ,told him the problem ,1st answer was front rubber hoses ,told him I replaced them ,his answer was master cylinder , Got a new unit bleared it and install dragging brakes fixed.
SCBlazer96
Apr 16, 2010 08:39 PM
xderkax
Jan 14, 2010 11:38 PM
upblazer95
Apr 4, 2009 08:27 PM
Hoelgi
17
Oct 20, 2007 08:49 PM
dashyman
Jan 12, 2007 11:28 AM
