brake question
Old Aug 18, 2013 | 09:06 PM
You'll have $20 in a new piston, $15 in a rebuild kit, and another $20 for a cylinder hone. OR, you can get one that has been professionally rebuilt, with a warranty, for $50.... your choice
Old Aug 18, 2013 | 11:58 PM
Twip's Avatar
Originally Posted by coolasice
^ make sure to use high temp silicone grease, not standard bearing grease
thank you sir, i forgot to mention the type of grease. good catch on your part!!
Old Aug 19, 2013 | 06:40 PM
coolasice's Avatar
coolasice will become famous soon enough
you can get them loaded with pads for 60-70 and a rotor is like 30-40... most times
better to replace then turn them, turning is usually 15-20 each...
Old Aug 19, 2013 | 06:42 PM
coolasice's Avatar
I made the $200 mistake before...now ALWAYS use silicone grease...
Old Aug 19, 2013 | 10:54 PM
AndrewO1991's Avatar
AndrewO1991 is on a distinguished road
inside pad means the slides need greased
Old Aug 20, 2013 | 04:15 PM
Hydraulic pressure will overcome any binding when you apply the brakes. If the guide pins bind, the outboard pad will not release. If the caliper piston binds, the inboard pad will not release.
Old Aug 20, 2013 | 04:27 PM
newguy's Avatar
1 step forward, o steps back
Old Aug 21, 2013 | 02:07 AM
Spree's Avatar
Spree is on a distinguished road
New calipers and rotors are cheap, go that route. Not sure where you guys are buying your parts from?
Rotor $32 front or rear one year warranty
Caliper $40 front or rear life time warranty (but yours can be fixed with a little elbow grease) for free! I did mine.
Pads $20 life time warranty
$52 new rotor, new pad, rebuilt caliper. I did it you can to!
Old Aug 21, 2013 | 05:36 AM
porkfriedrice's Avatar
porkfriedrice is on a distinguished road
Originally Posted by Captain Hook
If the inboard pad wears faster than the outboard pad, the caliper piston is not retracting, (binding in the caliper bore). If the outboard pad wears faster, there's a problem with the hardware, (guide pins binding etc).
Thanks for this info, great for future reference. Just did rear brake job on the Blazer, and the inboard pad on each side was worn to almost nothing, while the outboard pad on each side had barely any wear. Have a feeling that whoever had the truck before me replaced the pads without replacing the calipers, which I've learned from this forum is not a good idea when working on rear brakes. The difference in braking power is very noticeable.
Old Aug 21, 2013 | 06:02 AM
coolasice's Avatar
might want to check your math on that one... should be $82 per side....
