brakes
Old Sep 3, 2008 | 05:56 PM
bigbear1921's Avatar
bigbear1921 is an unknown quantity at this point
Default brakes
brake pad hard as a rock .replaced power booster 2years ago.is it thesame thing maybe .have bleed brakes and abs both
Old Sep 3, 2008 | 06:12 PM
Default RE: brakes
Its quite possible the booster is at fault again. If you remove the check valve from the front of the booster, you should hear a rush of air. If it does not do this, then the booster bladder is most likely shot.
Old Sep 3, 2008 | 06:13 PM
Default RE: brakes
thank you ill try it
poertsch
Apr 23, 2016 01:05 PM
goslats
15
Jul 31, 2015 09:19 AM
mowermechanic
Jan 31, 2012 09:01 AM
218persuader
Aug 20, 2010 06:11 PM
rnjohnson
Nov 16, 2009 08:39 AM
