Brakes
Old Jun 27, 2009 | 04:21 PM
BlueRanger's Avatar
BlueRanger is on a distinguished road
Default Brakes
1996, 4 whl. drv., 4.3. vortec, 213k., brakes feel like they would get tight then travel, would not lock tight. the abs doesn't seem to want o kick in. replaced the calipers and pads, still the same problem. replaced the master cylinder, still the same problem. check valve is good. no leaks on the lines. no abs warning lights showing. what should be my next step to diagnose?
Old Jun 27, 2009 | 11:03 PM
Bigringtravis's Avatar
Bigringtravis is on a distinguished road
Exclamation Brake lines...
I must tell you first that this is the wrong section for your post. It'll probably get moved so don't be surprised...
To answer your question:
You should have replaced the brakes lines from the frame to the caliper when you had it all apart. They're about $12~$13 each and it was a HUGE difference on my Blazer.
Good Luck!
Old Jun 28, 2009 | 06:50 AM
BlueRanger's Avatar
Thanks for the reply, and for the forum tip (It was a long day). The flex lines felt soild, there was no give in them. Should I still replace them?
Old Jun 28, 2009 | 07:33 AM
Yep! Blazers are hard on brakes!
poertsch
Apr 23, 2016 01:05 PM
goslats
15
Jul 31, 2015 09:19 AM
mowermechanic
Jan 31, 2012 09:01 AM
218persuader
Aug 20, 2010 06:11 PM
rnjohnson
Nov 16, 2009 08:39 AM
