Brakes
Old Jan 26, 2011 | 11:40 PM
Mange98's Avatar
Mange98 is on a distinguished road
Exclamation Brakes
Ok, so out of all the things I've done before, servicing brakes has not been one of them. First off, how do I properly remove the calipers? Secondly, removing the pads themselves and reinstallation of new ones? Thirdly, how do you bleed the brakes system? Fourthly, when driving, I have a constant squealing coming from the brakes, how do I fix this??
Old Jan 27, 2011 | 01:29 AM
Gimpy Blazer's Avatar
Gimpy Blazer is on a distinguished road
1) You may not need to remove the calipers if they aren't worn too bad or scored.
2 The pads just slip in and out but you do have to back the piston up. Big "C" clampis my favorite
3)If you don't renove the calipers you don't need to bleed the brakes.
4) Make sure you have shims on the brake pafs.
If you do have to pull them I suggest you go buy a manual because it's obvious you don't have one. It'll save you a lot of aggravation in the end. 2wheel drive modeels are slightly more difficult than 4x4s. The calipers are bolted on with 2 bolts each but you [retty much have to take everything apart to get the rotors off.
poertsch
Apr 23, 2016 01:05 PM
goslats
15
Jul 31, 2015 09:19 AM
mowermechanic
Jan 31, 2012 09:01 AM
218persuader
Aug 20, 2010 06:11 PM
rnjohnson
Nov 16, 2009 08:39 AM
