Brakes Hard to depress,
Old Aug 8, 2011 | 11:18 PM
dj00140's Avatar
dj00140 is on a distinguished road
Default Brakes Hard to depress,
1997 Chevrolet Blazer
Hey guys I am in trouble, basically I my brakes started to get hard to depress, not really hard but harder then usual, also when I depress the pedal it makes that air release sound like when you pump the brakes when the car is off, I just bled the brakes not to long ago, but one of the front brake lines came loose and I bled it but I didnt bleed the other front one but everything has been fine up until now, I looked at the brake fluid level and it was good but pretty dirty considering I flushed the brakes about 6 months ago maybe less. I checked the brake booster hose and check valve that runs from the booster to top of engine and I could only blow not suck, so that is good, any other ideas, any help is appreciated as this is me and my gf's only vehicle and we are broke! Also I am having another problem just incase it is related, I believe the code is p0102 low volt MAF circuit, I believe this is because I have a very weak battery that will die if I leave my lights on for more than 10 minutes. I am replacing this soon, can this have anything to do with it? Thanks.
Old Aug 8, 2011 | 11:51 PM
stlwaco's Avatar
stlwaco is on a distinguished road
sounds like the brake booster's internal diaphram is torn. You will need a new booster.
Get back to us after replacing the battery
Old Aug 8, 2011 | 11:57 PM
pettyfog's Avatar
Your brake booster is bad, may be causing the MAF problem as well as it is a vacuum leak
Just get one from a salvage yard, they dont go bad all that often
Old Aug 9, 2011 | 03:14 AM
dj00140's Avatar
Thanks guys I just posted a video in the tech section if anyone needs itt, sorry about the title I didnt get to finish it lol, \\
https://blazerforum.com/forum/articl...l-350-a-61936/
poertsch
Apr 23, 2016 01:05 PM
goslats
15
Jul 31, 2015 09:19 AM
mowermechanic
Jan 31, 2012 09:01 AM
218persuader
Aug 20, 2010 06:11 PM
dashyman
Suspension Tech
May 5, 2006 05:49 PM
