Suspension Tech Have a question about modifying your suspension? Ask it here.
Brake Pedal Will Not Depress
Old May 5, 2006 | 01:37 PM
dashyman's Avatar
dashyman is an unknown quantity at this point
Default Brake Pedal Will Not Depress
95 Blazer 4WD - when I go to depress the brake pedal sometimes it will not go down - if I release a bit and then retry it will brake - the antilock then seems to engage a bit at times
fluid level is fine and I'm pretty sure the pads and linings are ok
Please help - not a safe situation
Old May 5, 2006 | 01:52 PM
Dory's Avatar
Retired Super Moderator
Dory is a jewel in the roughDory is a jewel in the roughDory is a jewel in the rough
Default RE: Brake Pedal Will Not Depress
master cylinder?
Old May 5, 2006 | 03:09 PM
4lowlife's Avatar
Did you do any hydraulic work? Could the lines need a bleedin'?
Old May 5, 2006 | 03:33 PM
dashyman's Avatar
have not done any hydraulic work - only topped of resevoir with brake fluid
Old May 5, 2006 | 05:49 PM
Binz316's Avatar
Binz316 is an unknown quantity at this point
bleed the lines
dj00140
Aug 9, 2011 03:14 AM
zach bjorge
Mar 17, 2011 06:49 PM
lowe42
Dec 23, 2008 12:34 PM
05box
Apr 23, 2008 07:25 PM
apekim
Sep 15, 2007 10:46 AM
