Brakes Pulling Hard Left
Old Sep 4, 2008 | 10:46 PM
Blazer4U's Avatar
Blazer4U is an unknown quantity at this point
Default Brakes Pulling Hard Left
My 1995 Blazer is pulling hard to the left, but it is only occasionally and by that I mean it usually only does it when exiting the interstate on the off ramps. When I put my foot on the pedal, it will jerk hard left and then when I take my foot off the pedal and try again, the pedal is rock hard and I have very little braking action and no noticeable pulling in either direction. Seems about the third or fourth time I try, I get my brakes back. Talk about a hair-raising experience. This has only been happening since I power washed the undercarriage yesterday afternoon. Is it possible that grease, dirt or grime on the rotor or pads is causing this? Or does it sound like air in the line or ABS problem? I did have quite a build up of grime on the bottom.
Old Sep 6, 2008 | 10:09 AM
bjsx8f's Avatar
bjsx8f is an unknown quantity at this point
Default RE: Brakes Pulling Hard Left
it could be your rotor being rough on the side its pulling to.... a caliper going bad and sticking... I would take the caliper off and see how hard it is to push the cylinder back using a C-clamp.. If its pretty tough I would go ahead and replace the caliper. It should take a bit of twisting but not a lot of force.
Skitzoape
Mar 1, 2014 01:56 PM
stan kelly
Mar 10, 2013 06:05 PM
ComputerNerdBD
45
May 20, 2012 10:36 AM
cahlersmeyer
Nov 8, 2011 04:12 PM
F T P
Aug 9, 2009 01:45 PM
