Brakes and serpentine belt!
Old Jul 14, 2008 | 02:20 PM
natenorrish's Avatar
natenorrish is an unknown quantity at this point
Default RE: Brakes and serpentine belt!
Hey if6was9,
No worries - I tested the brakes out last night properly, foot to the floor felt the ABS kick in.. they are working but still quite easy to put the foot down. So you say only 2 inches movement, but guessing after those 2 inches it should be more firm and then the ABS kicks in when braking hard? Pretty sure somewhere in between the first 2 inches of movement the brakes kick in and slow the beast really well.
As for fully bleeding the system, we did that but don't think we did it properly! Do you happen to know what the difference between DOT 3 and DOT 4 brake fluid is?
Cheers
Nate
Old Jul 14, 2008 | 07:35 PM
portcqb's Avatar
portcqb is an unknown quantity at this point
DOT 3 is the older fulid spec and is required in these trucks. DOT 4 is a newer spec, some DOT 4 fluids are compatible with DOT 3 systems. It is a partly or fully synthetic fluid that will not compress correctly in a DOT 3 system unless it specifies DOT 4/3
Old Jul 15, 2008 | 10:33 AM
if6was9's Avatar
if6was9 is an unknown quantity at this point
ORIGINAL: natenorrish
Hey if6was9,
Cheers
Nate
The other difference between DOT 3 and 4 is the boiling point.
luvmychevy
Jun 8, 2011 11:46 AM
luigi408
Feb 3, 2010 03:07 AM
ooohtodd
Apr 3, 2007 09:27 PM
cimbali
Mar 25, 2007 03:29 PM
