Bravada 4wd actuator
Old Sep 7, 2015 | 02:29 PM
No false Bravada's Avatar
No false Bravada is on a distinguished road
Default Bravada 4wd actuator
Started getting a bit of a clicking, almost popping sound when making hard turns. Thought it was a CV axle, checked both and replaced the obviously bad one (small rip in boot, starting to spit grease) and the other one was fine. Still makes the noise. Tried changing the front differential fluid, used 80w90. The old stuff was in pretty bad shape, but it's got fresh stuff now. Still makes the noise. I was thinking that maybe the 4wd actuator or front axle actuator (I've seen both on RockAuto) is keeping the axle locked in and making that noise. Any ideas?
99 Bravada AWD, NV136 tc
Old Sep 7, 2015 | 09:12 PM
Bravada, (NV136) is not equipped with a 4WD front axle actuator. Both front axles are always engaged with the front differential. If it makes the clicking noise only on turns, CV joint is the most likely culprit, better check both of them again
Old Sep 7, 2015 | 09:30 PM
I know one should be good, since it was reman from AutoZone. I was planning on getting the next one next week anyway.
extreme
Jan 5, 2010 07:29 AM
stormshadow1
Jan 4, 2010 11:03 AM
markrd
May 8, 2009 01:39 PM
albapogal
Nov 10, 2008 02:25 PM
rooster
Feb 18, 2007 07:16 PM
