Breakline Troubles
Old Oct 12, 2013 | 06:42 AM
Hammerwolf's Avatar
Hammerwolf is on a distinguished road
Default Breakline Troubles
I have a 2001 Chevy Trail Blazer. I have to get parts under "Blazer" due to only so many of these Trail Blazers being made. At any rate, I seem to have leaking somewhere under the master cylinder and also between the drivers side front & rear doors along the rear main supply line. First question, should I Isolate the area of the leak by clamping off the 4 rubber tubes on the brake lines with vice grips or other type of clamping devices- remove one vice grip at a time-then press on the brakes to find exact leak locations? 2nd question, Is the rear main supply line running down the frame rail 1/4" and is it easier for me to bend it after feeding the new line through?
Thanx, Hammerwolf
Old Oct 12, 2013 | 09:21 AM
toyhauler1283's Avatar
toyhauler1283 is on a distinguished road
Yea depending on what brake line you get its pretty easy to bend by hand
Old Oct 12, 2013 | 10:00 AM
rexazz2's Avatar
DO NOT PINCH off lines , it can collapse them and cause brake drag and all other types of issues
refill fluid and start pumping brakes , look for the dripping
if you can get "armoured" brake line it wrapped with spring and even easier to bend a cheap bending tool is another option
remove the entire length you need to replace
takes the fitting ends to the part store so you can match size, flare style
the parts store can give you a combination of shorter lengths and unions to make reinstallation easier
Old Oct 13, 2013 | 03:56 AM
Hammerwolf's Avatar
Thanx alot for the advice.
Old Oct 13, 2013 | 04:05 AM
Hammerwolf's Avatar
[QUOTE=rexazz2;603487]DO NOT PINCH off lines , it can collapse them and cause brake drag and all other types of issues
reinstallation easier[/QUOTE
Thank you bigtime for all the great info. It is much appreciated!
Kellogg
Jan 31, 2010 04:28 PM
jaybird33081
Jan 4, 2010 11:19 PM
baja457
Oct 28, 2007 08:21 AM
getonerd
Sep 28, 2007 07:20 PM
2blzers
May 13, 2007 09:09 PM
