I having amp troubles
Old Sep 27, 2007 | 10:37 PM
getonerd's Avatar
getonerd is an unknown quantity at this point
Default I having amp troubles
I got a visonik v217sx
Each time the bass thumps and/or i turn the music up the amp goes into protection mode and then cuts out (no power or protection led )
but when i goes out use my volt meter im getting no signal from the remote wire and my power wire
well its not the amp i had a old amp laying around and it was doing the same thing
any suggestion
bad ground
bad remote
should run the remote to fuse box
but i just starting happing after replace the radio(Pioneer to a
Panasonic) do you think i just hooked up the wrong remote wire
it was working fine with the pioneer[/align]
Old Sep 27, 2007 | 11:11 PM
hillbillyinOhio's Avatar
Default RE: I having amp troubles
try this, take a small piece of wire, strip off both ends, put one end into the remote, and the other with the 12v battery line. then if it cuts out, you either have a bad ground, the impedance from the subs is too low for the amp to handle, or the amp is bad.
if it plays fine, pull out the deck and check voltage on the remote. worse case scenario, run to the fuse panel .
Old Sep 28, 2007 | 07:20 PM
blznlowxtreme's Avatar
blznlowxtreme is an unknown quantity at this point
mine done the same thing when i re-wired my blazer with 4-gauge, and my ground had slipped out of the connecter but was still rubbing the frame, and everytime i tried to turn it up it kicked into protect
JohnBarJB
Sep 28, 2020 07:34 PM
95blazey
Jul 16, 2013 12:11 AM
bman22
14
Jan 14, 2013 08:23 PM
mcanter23
Sep 5, 2010 09:36 PM
tjbmxrider
Mar 25, 2008 06:09 AM
