broadcast code sgk
Old Mar 26, 2009 | 03:20 AM
  #21
H-D's Avatar
H-D
H-D is on a distinguished road
Is the "Security" light staying on, or blinking? Also, the ground connection at the gauge sender/ pump access may be lacking, since both are effected. For grins, I'd pull the fuel filter & "bump" the input side on a paper towel/rag & look for way fine metallic debris (as well as loads of silt). Clogged filters overheat pumps & the metallic debris is a tell-tale.
Old Mar 28, 2009 | 02:08 AM
  #22
blkblazer's Avatar
blkblazer is an unknown quantity at this point
Default sgk
Put battery on trickle charge overnight. Started right up next morning. That is second time it did this. Now I am looking at defective battery? Enough power to crank but not enough voltage to kick in fuel pump.Possible?
Bought new battery not the problem. Looking at alternator maybe voltage regulator is shot. Key on not running voltage meter leaning way to the left.
must be sick of me by now so I will give ya all a break thanks for the help.
92s10Blzr
Dec 7, 2009 03:12 PM
nitro7
Dec 1, 2009 06:27 PM
jcortes63
Oct 30, 2008 01:03 PM
lostatsea85
Jun 30, 2008 10:06 PM
lostatsea85
Jun 23, 2008 02:44 PM
