Broken ball joint 2001 2WD
Old Feb 20, 2014 | 04:18 PM
Joey1986Z's Avatar
Joey1986Z is on a distinguished road
Default Broken ball joint 2001 2WD
Sunday, while I was out of town (I am always out of town when this thing breaks down) My wife and children where in the Blazer and made a turn into Kroger and the wheel fell in and they were stranded. The Blazer was towed home.
I returned today to see that the Lower ball joint on the driver's side is broken!
I am so glad they were traveling slow when it broke! This same side had the front upper control arm shaft bolt break 2 years ago and the rear bolt broke broke 4 months ago. All at low speed. Thank God!
Now the lower ball joint broke.
What does it take to remove this joint from the lower control arm? What tools?
Any tips? Why is all this suspension stuff breaking? Thanks!
I am about ready to park it as all these parts are breaking that can be life threatening.
Last edited by Joey1986Z; Feb 20, 2014 at 04:19 PM. Reason: Corrections. added information
Old Feb 20, 2014 | 05:08 PM
Lower ball joints on 2WD are pressed into the control arm. Requires a special press to remove the old one, and to install the new one. Most auto parts stores rent the tool kit. Don't go cheap on the parts, use Moog.
Edit: ball joints break if they're not lubed often enough.
Old Apr 18, 2014 | 04:04 PM
Joey1986Z's Avatar
Well I am coming back with my tail between my legs.....
My fault altogether. This thing has grease fittings!!
My 1984 K10 4X4...Nope
My 1986 Z28.... Nope.
This blazer......YES!
That's what I get for ASSuming!
Anyway, I rented the kit and replaced the joint with intentions of changing them all. They did all get lubed!!
Well, now to the next problem!
Old Apr 18, 2014 | 09:49 PM
spittybays
Guest
Posts: n/a
Something else could be wrong. They should have come pre- packed with grease.
Hope I'm wrong.
Old Jan 25, 2021 | 02:58 PM
marjom's Avatar
marjom is on a distinguished road
A sudden shock from a pothole or other obstruction in the road can damage this system. Over time, these shocks will wear out the components of your vehicle suspension, thus reducing the life of these components. Absorb bumps and other shocks. The vehicle turns in response to steering.
Davecubs14
Jun 4, 2016 10:09 AM
apaplayer
Apr 8, 2013 08:45 PM
dropwiser
13
Apr 2, 2013 03:24 PM
razman
Mar 23, 2010 07:26 AM
Jorgen
Jul 24, 2007 08:40 AM
