Broken Steel Fuel Line
I broke the Steel fuel line at the tip where it connects to the quick disconnect coming from the fuel pump. I broke about a centimeter of the steel line which is the part with the ridge the quick disconnect connects to. Is there any way I can Repair this or do I need a new Steel line? Thanks
I think your going to have to replace the line. How did you break the steel tubing?
I was just using the little plastic quick disconnect tool to get the plastic line off and the steel snapped
I dont know if this is stupid or not, but could this be what I need? http://www.dormanproducts.com/p-15880-55180.aspx
if that is the end that is broken off,
you might be able to get a brass connector compression fitting and
and splice in that end with some flairs up a ways
on the line somewhere.
AbbyNormal
03-25-2013 08:27 AM
2manybroke
12-30-2007 07:59 AM
MindlessCorpse
09-22-2007 06:29 PM
2000, blazer, broken, chevy, compression, disconnect, disconnects, fitting, fix, fuel, line, lines, quick, splice, steel
