A/C clutch fuse problem
Old Mar 31, 2023 | 06:12 AM
jimmy_for_ever's Avatar
jimmy_for_ever is on a distinguished road
Exclamation A/C clutch fuse problem
Hello everybody
I have a problem in my 00 GMC JIMMY in HVAC system , the problem is that 10 amp A/C clutch fuse blown every time I switch on the a/c this problem start after I add double cooling fans on a/c condenser. I was power these two fans from air compressor +12 clutch wire so, I was think maybe it take to much amps that's why the fuse blown. I was trying to change the fuse from 10 amp to 20 amp fuse it works great but after few months the relay gets hot and the terminal melt and become loose. Today I change the fuse box today but I don't know how can I connect the a/c condenser fans without effect a/c clutch power and operation.
Can any one help me to re-wire the fan correctly?
thank you
Old Mar 31, 2023 | 09:17 AM
GeorgeLG's Avatar
Originally Posted by jimmy_for_ever
Hello everybody
thank you
I would not increase the existing fuse value, you can start a fire.
I would run a new fused power wire of the correct gauge to the new device.
George
Old Mar 31, 2023 | 10:05 AM
George
What George said. Then, you can use the wire that powers the AC clutch to trigger a separate relay for your fans. This would not be ideal, though, because the fans should run continuously while the AC is operating, not just when the clutch is engaged.
The best option is to buy a fan controller made specifically for this purpose, and wire it according to the manufacturer's instructions.
Old Mar 31, 2023 | 02:47 PM
Can you please send for me an example of these fan controller because I search but I couldn't find one ?
Old Mar 31, 2023 | 03:09 PM
This is what I'm using, but there are many others available from places like Summit Racing.
jatkins3983
Oct 23, 2013 08:28 PM
Uncle Buck
Sep 28, 2012 02:21 PM
fiferguy
Jul 29, 2012 09:38 PM
carterx
May 19, 2009 08:07 PM
tjbmxrider
Apr 7, 2008 08:40 PM
