A/C Clutch, metal to metal sound
If you have a caliper (measuring device), you can measure from the end of the shaft to a reference point on the outer hub. Take a starting measurement, then take another measurement after you move it a bit.
i to work in the a/c reman. take the belt off an check if ur bearing is good. the bearing my b going out. but if ur bearing is good just get that tool to pull the hub out a little an u should b good to go. just make sure that it still ingages after u pull it out.
ComputerNerdBD
Feb 29, 2012 08:09 PM
blazinloud
24
Oct 1, 2011 05:33 PM
MintyMadness
Jul 13, 2011 12:37 AM
1995, ac, air, airconditioning, blazer, chevrolet, chevy, clutch, clutchs, compressor, conditioner, correct, puller, pulley, remove
