A/C Compressor not kicking on
Old Apr 7, 2012 | 11:37 AM
pettyfog's Avatar
To check out the control signals, look at wire going into the 'clear / natural / no color' plug at the VCM {computer}
Pin 1 {Dark Grn/white stripe} should be ground if heater control and ACcum cycling sw and hi-press cutout allow and call for compressor
Old Apr 8, 2012 | 02:02 PM
67dad's Avatar
67dad is on a distinguished road
Default Fixed...Thanks to all on thread!
Originally Posted by Captain Hook
See post #2 for some preliminary tests. Also need to check the high pressure cut out switch on the rear of the compressor. It disables the clutch if pressure is too high, but it can fail and keep the clutch from engaging as well.
Capt. Hook: When rechecking everything per post #2, we found that bypassing the low pressure switch DID kick in the compressor (we must have had a bad jumper when we tried earlier). Freon added. Pressure switch works too after freon. Crossing our fingers the leak was very small.
Thanks for the help!
Happy Easter! He is Risen!
Old Apr 8, 2012 | 11:05 PM
mrkevinmjr's Avatar
mrkevinmjr is on a distinguished road
make a mark to check off to check the freon in my cooling system before summer arrives ... god forbid the mrs has to sweat while i jam with the windows down and sunroof open... and some awesome tunes...
RomanKoch
Aug 11, 2013 03:09 PM
gmcjimmy_94
Dec 30, 2010 12:37 AM
acavill
Apr 3, 2010 05:19 PM
mahplane
Dec 29, 2006 07:34 PM
MusicMaverick
Feb 13, 2006 02:40 PM
