A/C Issue
Old May 23, 2009 | 07:30 AM
Biohazed's Avatar
Default A/C Issue
Ok my 95 AC works great when it works ... the issue I'm having is as follows, the Compressor will not always engage, When this happens i have to disconnect the connector to the switch that turns the compressor on and aoff and plug it back in then it works great for 20-30 minutes then stops working again. I'm thinking its probably the switch that the connector goes to that could be bad, anyone else have any ideas?
Old May 23, 2009 | 07:42 AM
hkellogg's Avatar
hkellogg is an unknown quantity at this point
do you have a pressure reading on the high and low side ? Do you mean the plug on the side of the compressor ? To me truthfullly it sounds like an underfilled system or a short, but to give a better answer I would like to know what the system is running at on the high and low side while the compressor is engaged
Old May 23, 2009 | 04:24 PM
brcidd's Avatar
brcidd is an unknown quantity at this point
Sounds like a wide air gap to me........
Old May 23, 2009 | 06:28 PM
portcqb's Avatar
portcqb is an unknown quantity at this point
Which switch are you disconnecting the low pressure cutout,the high pressure cutout, or the clutch engagement switch?
Old May 23, 2009 | 08:41 PM
Biohazed's Avatar
its the connector that goes to the silver canister that engages the compressor. I actually drove it all day today and it only happened once. But I had a problem with it last year with the same problem but it wouldnt engage for more than a few minutes. But I recharged the system on Friday evacuated and added 3 12oz cans of r-134 to it and its been working alot better since.
Old May 23, 2009 | 09:25 PM
portcqb's Avatar
Yeah thats the low pressure cutout its actually to tell the compressor to shut off so it doesnt starve itself of oil. If all 36oz went in its a little bit over but only a few onces,it should stay engaged as long as the evaporator isnt freezing over. If you have it on max a/c and high fan it should stay engaged for quite awhile
brian79z
32
Feb 23, 2015 07:13 PM
99bblazer99
Jun 15, 2013 08:38 PM
J.R. Clay
Mar 16, 2011 12:33 AM
extreme
Jan 5, 2010 07:29 AM
