A/C Issues I searched but could not find a problem like mine
Old Aug 16, 2009 | 02:18 PM
fijianrocket's Avatar
fijianrocket is an unknown quantity at this point
Default A/C Issues I searched but could not find a problem like mine
Hey all.
Vehicle:1995 Chevy Blazer 4.3L 4 door 4X4
I have a problem with the air condition system.
Here are several things it does:
When i first start the car the a/c will blow cold/cool and then after a few minutes. Around 5 it will begin blowing in hot air. Then when i come to a stop light or an extended stop after hitting the brake the ac will blow cold again but this is not always a guarrantee.
Also sometimes it will stop blowing cold air when i accelerate. I know the compressor is designed to shut off at high rpms so it wold not get damaged.
I also checked the a/c vacuum reservoir and applied new vacuum hoses.
The system has been recharged this season and when i put a gauge to it it reads within specs.
Very rarely the ac will blow cold continously for about 15 minutes. I think thats happenned twice this summer.
Oh and one other thing on much cooler days the ac is able to blow cooler air for a bit longer.
Im very mechanically savvy with everything except a/c systems. never had problems with any of my cars except this one. Please help.
Old Aug 16, 2009 | 02:28 PM
hkellogg's Avatar
hkellogg is an unknown quantity at this point
Tap on the clutch when it's not engaged but should be on and get back to me
Old Aug 17, 2009 | 08:16 AM
it only happens when driving.the clutch actually engages when it sits. i will try to park it and leave it running and do what you said today.
Old Aug 17, 2009 | 09:42 PM
95Jimmy's Avatar
95Jimmy is on a distinguished road
I'll be watching this thread- I have a 95 Jimmy 4 door 2wd and I'm having a very similar problem with my AC.
Old Aug 25, 2009 | 11:47 PM
Okay so the compressor does turn off from time to time. Now there is also a roar coming from the engine. Im thinking that the fan clutch is going out. Could this be a cause by any chance?
Anyways when i hit the compressor with a hammer it comes back on. should i replace it?
Old Aug 26, 2009 | 09:24 AM
bigdaddykane93's Avatar
bigdaddykane93 is on a distinguished road
that could also be your pressure cycling switch too. next time its blowing warm arm, see if the compressor is off, then tap on the pressure cycling switch thats bolted near the dryer and see if the compressor goes on. if it does, then you need a new switch. which is cheaper and easier to replace than replacing the compressor especially that the compressor works and holds the freon.........
Old Feb 2, 2010 | 10:07 PM
95Jimmy's Avatar
Bring it up from the dead! I finally took my Jimmy down to a local mechanic today due to the same symptoms the OP was describing. With mine it was because the air gap in the compressor clutch was not set properly. Now she works like new! Hope that helps somebody out!
Little Roober
Lifting Tech
Feb 13, 2012 10:02 PM
blazerJim1701
Jun 15, 2010 09:16 PM
timmi79
Jan 6, 2010 10:52 AM
redpeppers
Apr 7, 2007 04:55 AM
j1cs
Jan 15, 2007 05:03 PM
