a/c not working
Old Apr 21, 2008 | 05:18 PM
rubrod84's Avatar
rubrod84 is an unknown quantity at this point
Default a/c not working
here it is ..... my wife's blazer a/c does not work, the a/c clutch does not engage ...relay and fuses are functional....oh yea it is at 2000 chevy blazer LS 4.3 liter... manual climate control....( three ***** ) i try to jumpm the pressure switch at the canister with a paper clip... still nothing....im at a loss right now i read over 75 pages on posts looking for a/c problems...but i am still confused.. well any help will be appreciated thanks.. i read the whole low pressure posts butthat why i tried the whole jumpin of the sensor at the canister,.... also if i manually give the clutch juice, and the compressor kicks on.... i.e. with a power probe.
Old Apr 24, 2008 | 06:48 PM
jukdd's Avatar
jukdd is an unknown quantity at this point
Default RE: a/c not working
if the ac clutch does not engage, that's probly why. mine doesn't work either, and the A/C clutch doesn't engage, all i get is warm air.
Old Apr 25, 2008 | 12:08 AM
When you manually power the compressor clutch, does the system perform properly (ie. cold air)?
Old Apr 25, 2008 | 06:02 AM
rubrod84's Avatar
no it does not.... the compressor is now kicking on and off... cycling, but stilll no cold air.., i tried one of the re3charge kits but when i hooked it up it registered full when the clutch kicked on it dropped to empty...., im assuming i have a leak somewhere... so iguess i have to find the leak... the weird thing about it is when i tried adding some it the gauge registerd in the yellow saqyin its overfull, (clutch not on) but whenthe clutch engages, the gauge drops to empty....
Old Apr 25, 2008 | 11:08 AM
garry2000blazer's Avatar
garry2000blazer is an unknown quantity at this point
You should expect the gauge to drop when the clutch engages. When the clutch is not engaged, the entire system is basically at the same level of charge. When the clutch engages, it sucks freon out of the low pressure side to create the high pressure needed for the system to work. When you charge you should be adding the freon to theLOW pressure side while the system is operating (clutch engaged) to the desired pressure.
Old Apr 29, 2008 | 06:23 AM
rdhack's Avatar
rdhack is an unknown quantity at this point
Try the Forum at ACKITS.com
big_charms@hotmail.com
Mar 20, 2014 10:26 PM
mjw1991
Feb 24, 2013 10:18 PM
bootlegger
Dec 14, 2010 05:18 PM
218persuader
Aug 20, 2010 06:11 PM
chrisblaze
Dec 6, 2009 12:27 AM
