A/C on off
Hello everybody
I have this problem but I don't why it occurs in my GMC jimmy 00, when I park it in sun or weather very warm and switch on A/C the clutch continue engage and disengage the compressor is new just replaced before 1 year with all o-rings and drier accumulator also, I install dual fans on a/c condenser and there are already dual fans on radiator . I check the pressure of low side with my pressure gauge and its 44 psi when the climate temp is 42 C (106 F) above 20% humidity in the least recommend service manual pressure.
Thank you
Thank you
How are you testing the low side pressure if the compressor clutch is turning on and off? How fast does it cycle? What is the center vent temperature with the fan on high? Is the accumulator cold and sweaty?
George
George
No, when I check it in morning around 6:00 am and it never cycle on off . This happen only when the weather hot, Its very cold like ice and yes accumulator cold and sweaty.
- I don't know what you mean
-I don't check it today
thank you GeorgeLG
