A/C pressure question
Its been a while since I've had functioning ac in my blazer, so I rented a manifold test gauge and checked the pressures.
Here are my results:
Engine off/static test-
Low side: 20 psi
High side: ~25 psi
Engine on, idling, ac and fan on max-
Low side : 0 psi
High side: 75 psi
Engine on, @ 1500 rpm, ac and fan on max
Low side: low side gauge showing vacuum: 10 hg
High side: ~85 psi
According to this PDF from sanden ac compressors, I might have a restriction somewhere in the system, and low on refrigerant too? I need some help interpreting my test results, thanks for the info guys,
Low side: 20 psi
High side: ~25 psi
Low side : 0 psi
High side: 75 psi
High side: ~85 psi
Jackrabbit
01-13-2010 09:54 PM
Spartan66
07-11-2008 02:34 PM
