A/C Problems
Old Jul 3, 2012 | 02:30 PM
devlinmcguire's Avatar
devlinmcguire is on a distinguished road
Default A/C Problems
Hey everyone,
About a month ago I was given a 95 Blazer (some nice church friends who are moving to Africa didn't need it) with 155k. The A/C has not worked since I got it. This summer is really bad so I picked up a can of freon to try and fix it. First thing I noticed as that the compressor wasn't spinning. After I added a little freon it would go on and off at about 2 second intervals. I added some more freon but could never get a good pressure reading since the compressor was constantly on and off (but it was going in between really low and really high). I then stopped adding freon when it made a loud squealing sound that scared me. Two days later I tried again but this time the compressor wouldn't turn on even after adding a little more freon. I jumped the compressor to the battery to try and get it to suck up some more freon but then, even with the compressor running, the pressure on my little refrigerant-refill-thing was at zero (but I know there is pressure in the system from poking the high and low values).
I'm stumped. Any suggestions or ideas would be valued.
Thanks.
Old Jul 3, 2012 | 02:49 PM
50lb_cat's Avatar
It usually short cycles for awhile before staying on all of the time. How much did you put in? It may just need some more or it could be a bad pressure switch or plugged orrifice tube.
Old Jul 3, 2012 | 03:17 PM
It's hard to say...probably in the 5-10oz range. How do I check the switch and the orifice tube?
Old Jul 4, 2012 | 12:31 AM
egbert567's Avatar
egbert567 is on a distinguished road
I'm tuned in! I'm chasing a leak....I have put dye in but I am only seeing it around the accumulator. This could be from me putting the dye in. I hate throwing parts at it!
Old Jul 4, 2012 | 02:00 PM
50lb_cat's Avatar
Old Jul 4, 2012 | 02:12 PM
Rottidog's Avatar
https://blazerforum.com/forum/2nd-ge...eadache-71257/
And this one, Captain Hook is very informative!
Aanenson
Apr 14, 2011 09:12 PM
upblazer95
Apr 4, 2009 08:27 PM
