A/C problems
Old Dec 27, 2006 | 05:47 PM
ron36535's Avatar
ron36535 is an unknown quantity at this point
Default A/C problems
I think my clutch is going my on my a/c, is this something I can replace, or is this a shop job? If I can do it is there a break down picture of the part I need to see ?? help !!
Old Dec 27, 2006 | 05:54 PM
lastcoupe's Avatar
lastcoupe is an unknown quantity at this point
Default RE: A/C problems
You should take your VIN to a parts counter, they can tell you if it is available AND show you an exploded diagram..heck even print one for you to take home. Some are available seperate some aren't....they aren't too bad to change but you will probably need at least a spanner wrench and possibly a special puller...they also need to be shimmed correctly..which usually requires disassembly at least two or three times.
Old Dec 27, 2006 | 07:35 PM
rooster's Avatar
rooster is an unknown quantity at this point
mine went and i said f' it untill summer, so in the meantime i got a bypass pully for real cheap. i will replace the whole compressor then. that clutch was a b'itch to try and get off
Aanenson
Apr 14, 2011 09:12 PM
upblazer95
Apr 4, 2009 08:27 PM
